This Summer i was building a Recumbent bike of my own design I ran into a Gearing problem the bike seemed rellay hard to peddle no matter what the rear gear was set as. I concluded that it has to be the rear break in the chain i have. I ran 2 separate chains to offset some on the pulleys and make rear gear work properly. I was wondering if anyone had A way for me to keep a 1.1 gear ratio to the back end. Iv been reading a bit about ratios but i dont really understand them much if i use same tooth at front and same tooth sprocket at back will that keep it so the ratio is the same as just one sprocket at the front????????????
